Brake squeal
117,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
DAVE KRZEMINSKI
My brakes squeal when applied however it is not the pads. The steering wheel is not jerking either. What could this be?
Nov 11, 2017 at 7:20 AM
SATURNTECH9
  • 30,868 POSTS
If the brakes squeal when applied then pads or shoes are squealing somewhere. Are you saying it is not the pads because they are not worn out?
Nov 11, 2017 at 8:23 AM
CJ MEDEVAC
  • 11,000 POSTS
If you replaced the pads, were they the lower end (cheaper) that were available?
Did you have the rotors machined (or replaced with new ones)?
The Medic
Nov 11, 2017 at 8:25 AM
SATURNTECH9
  • 30,868 POSTS
If you used cheap pads when you replaced them or did a pad slap no turning the rotors or replacing the rotors they can make a lot of noise.
Nov 11, 2017 at 8:28 AM
