Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Versa
Brakes
Symptoms
Squeal
Brake squeal
2010 NISSAN VERSA
117,000 MILES • 1.4L • 4 CYL • 2WD • AUTOMATIC
DAVE KRZEMINSKI
MEMBER
1 POST
My brakes squeal when applied however it is not the pads. The steering wheel is not jerking either. What could this be?
Nov 11, 2017 at 7:20 AM
SATURNTECH9
Experienced Mechanic
If the brakes squeal when applied then pads or shoes are squealing somewhere. Are you saying it is not the pads because they are not worn out?
Nov 11, 2017 at 8:23 AM
CJ MEDEVAC
If you replaced the pads, were they the lower end (cheaper) that were available?
Did you have the rotors machined (or replaced with new ones)?
The Medic
Image (Click to enlarge)
Nov 11, 2017 at 8:25 AM
SATURNTECH9
If you used cheap pads when you replaced them or did a pad slap no turning the rotors or replacing the rotors they can make a lot of noise.
Nov 11, 2017 at 8:28 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
