When slowly braking it the pedal goes to the floor slowly
117,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
BKP
The truck does not stop very good at this point. But when I pump the brake pedal just slightly, before applying it, the brakes work fine. I have no leaks and reservoir is full. Could this be the mater cylinder?
Jul 18, 2019 at 5:08 AM
Good afternoon,
If you have no leaks, then it does sound like a master cylinder.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
NOTICE:
Release the vacuum from booster by depressing the brake pedal several times.
Then remove the brake master cylinder from brake booster.
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. DRAIN BRAKE FLUID
NOTICE:
Immediately wash off any brake fluid that comes into contact with any painted surfaces.
3. REMOVE CLUTCH RESERVOIR TUBE (for Manual Transmission)
(a)Disconnect the clutch reservoir tube from the reservoir.
4. REMOVE BRAKE MASTER CYLINDER SUB-ASSEMBLY
(a)Disconnect the brake fluid level warning switch connector.
(b)Using a union nut wrench, disconnect the 2 brake lines from the brake master cylinder sub-assembly.
(c)Remove the 2 nuts, and then pull the brake master cylinder sub-assembly out of the brake booster.
(d)Remove the O-ring from the brake master cylinder sub-assembly.
NOTICE:
* The master cylinder requires careful handling. Do not allow the master cylinder to receive any impact, such as from being dropped. Do not reuse a master cylinder that has been dropped.
* Do not strike or pinch the master cylinder piston, and do not cause any damage to the master cylinder piston by any other means.
* Release the vacuum from booster by depressing the brake pedal several times.
* When installing the brake master cylinder sub-assembly onto the brake booster, or when removing the brake master cylinder sub-assembly from the brake booster, make sure that the brake master cylinder sub-assembly is kept horizontal or its tip faces downward (the piston faces upward) to prevent the master cylinder piston from falling off.
* Do not allow any foreign objects to contaminate the master cylinder piston. If a foreign object gets on the piston, remove it by using a piece of cloth and then apply an even layer of lithium soap based glycol grease around the circumference (sliding part) of the piston.
* Do not use any other type of grease or fluid.
Jul 18, 2019 at 6:42 AM
BKP
Thank you very much. This was extremely helpful. it is going to be hot this weekend but this job is going to have to happen. Thank you.
Jul 18, 2019 at 9:22 PM
You are welcome.
Always glad to help.
Jul 18, 2019 at 9:40 PM
