How do you decompress the cylinders to put new brake pads on?
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
TOYPACIFIC
  • 159 POSTS
Hi guys, I was going to do a brake pad replacement and was curious as to how to decompress the cylinders to put the new pads on. Thanks in advance.
Mar 6, 2024 at 10:31 AM
  • 110,248 POSTS
There are special tools that you can purchase to do this. However, it can also be done with one of the old brake pads and a large C clamp. First, place the inner worn brake pad over the caliper pistons. Then attach a C-clamp on the old pad and the rear of the caliper, making sure not to touch anything that can be damaged. When you tighten the clamp, the pistons will be pushed back in by the old pad.
When you do this, take your time and don't force it too fast. I usually open the brake master cylinder cap but place a shop towel around the opening to catch any fluid that comes out. Or you can open the caliper bleeder and allow fluid to exit at that point. Just make sure to re-tighten the bleeder right when you release pressure.
One other thing, before depressing the caliper pistons, spray any dirt off the rubber boots and make sure the slid pins are clean and lubricated.
Take a look through this link. It explains how to replace the brake pads. Included is depressing the caliper piston. Take a look and let me know if this helps. Note: The link indicates a front-wheel drive pad and rotor replacement. The logic is the same. However, if you don't plan to replace the brake rotors, there is no need to remove the caliper bracket.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Take care and let me know if this helps or if you have other questions.
Note: I believe these vehicles all had rear drum brakes. Thus, the recommendations above are based on front pad replacement.
Mar 6, 2024 at 11:41 AM
TOYPACIFIC
  • 159 POSTS
Thank you for this info. I’ll go over the link you added. If I have any other questions, I’ll be sure to get back to you. I appreciate this.
Mar 6, 2024 at 12:01 PM
  • 110,248 POSTS
You are very welcome. Take your time and if you need help, let me know.
Mar 7, 2024 at 9:04 AM
