Brake problem
154,122 MILES
ALEXANDE SCOTT
Brakes seem to be coming on when driving. I have replaced the master cylinder, but the problem is still there.
Apr 7, 2017 at 11:25 PM
HMAC300
  • 48,601 POSTS
scan for codes see if it is an ABS unit problem. then check front brake hoses, may be keeping pressure on calipers. easy way to test is see if fluid comes out caliper with pressure when sitting still with brakes not applied.
Apr 8, 2017 at 12:44 AM
