Brake problem
270,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
BEETLEPUNK21
  • 127 POSTS
Hello!
I’ve got an issue with the front driver side braking system. I thought it was the brake caliper but i got a new one and it’s still sticking and not releasing. Do you think it has something to do with the brake line and/or the ABS module? I’m stumped. Thanks in advance!
Apr 15, 2023 at 4:41 AM
BRENDON S
  • 653 POSTS
Hello Beetlepunk21,
Sounds like you may have a brake hose that has collapsed internally. It will allow brake fluid to pass through when brakes are applied but it won't let it retract back into the system keeping the caliper stuck.
I would replace the brake hose, bleed the brakes and let me know how it goes. To release the pressure in the caliper just unscrew the bleeder valve.
Hope this helps. Let me know if I can help further.
Thank you,
Brendon
Apr 17, 2023 at 12:33 AM
BEETLEPUNK21
  • 127 POSTS
Okay, thanks Brendon!
Apr 17, 2023 at 10:37 PM
BRENDON S
  • 653 POSTS
Good morning, BEETLEPUNK21,
You're welcome. Let me know how it goes or if I can help further.
Thank you,
Brendon
Apr 17, 2023 at 11:00 PM
