When applying the brakes there is a wheel screeching noise and car does not stop
569,200 MILES • AUTOMATIC
VICTORIA238
  • 11 POSTS
Hi. I don't know what is wrong with the brakes but every time I pressed it I hear the wheel screeching like when hard braking wheel screeching, but for me I hear screeching wheels but my car does not stop. Sometimes speed decreases but very slowing. can someone help ASAP? Thank you
May 7, 2019 at 7:29 PM
Good morning,
I would not drive it until you have it examined and fixed.
It sounds like there is a problem with the pads contact with the rotor. It may not be making contact for some reason such as no lining left and the car will not slow down correctly.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
May 7, 2019 at 9:01 PM
VICTORIA238
  • 11 POSTS
can't be the pads. I changed them six months ago with a certified mechanic. I did not get any problems with the brakes all this time.
May 7, 2019 at 10:21 PM
That was six months ago and this is now.
They need to check again as you have an issue somewhere with the application.
May 8, 2019 at 12:44 AM
VICTORIA238
  • 11 POSTS
is it normal to have problem after six months of repair?
May 8, 2019 at 3:12 AM
All depends on what brand parts were installed and the type of driving you do.
Is it normal? No, it is not. That is why it needs to be checked carefully.
May 8, 2019 at 3:21 AM
VICTORIA238
  • 11 POSTS
What do you mean by type of driving?
May 8, 2019 at 3:44 AM
Stop and start. Highway. Driving too fast and abusing the brakes to stop. Riding the brake pedal while driving.
May 8, 2019 at 3:48 AM
VICTORIA238
  • 11 POSTS
I always ride on the brake pedal while driving.
May 8, 2019 at 3:55 AM
That is not good. You should never ride the brakes at all. You are overheating them.
May 8, 2019 at 3:57 AM
VICTORIA238
  • 11 POSTS
Really. I never got any problems with the brakes. I drove like this for nine years and never had brake problems, until now.
May 8, 2019 at 4:48 AM
You need to have them checked.
May 8, 2019 at 5:44 AM
VICTORIA238
  • 11 POSTS
Yes.
May 8, 2019 at 5:59 AM
VICTORIA238
  • 11 POSTS
yes
Keep us updated.
May 8, 2019 at 6:02 AM
VICTORIA238
  • 11 POSTS
yes okay.
May 8, 2019 at 6:23 AM
Just want you to be safe driving.
May 8, 2019 at 6:32 AM
VICTORIA238
  • 11 POSTS
Hi, mechanic told me that it was related with the gas pedal. when i remove my foot from it, it seemed that the gas pedal remain engaged and when I pressed the brake pedal the tires screech.
May 12, 2019 at 9:35 PM
That means the brakes are locking up.
Did he repair it for you?
What was the repair?
May 12, 2019 at 11:54 PM
DAVE213
  • 38 POSTS
Yes he has repaired it.
May 13, 2019 at 12:00 AM
Okay, and all the noise is gone now and the fuel pedal is fixed?
May 13, 2019 at 12:01 AM
VICTORIA238
  • 11 POSTS
yes, they are fixed.
May 13, 2019 at 5:03 AM
Good. No more noise?
May 13, 2019 at 10:16 AM
