brake pedal pumps up, let it sit a few minutes it loses pedal it goes to the floor. Just installed new calibers and rotors and pads on front, re-bled all fronts and master cylinder, always kept fluid topped off. trouble started when trying to bleed passenger side, could not get out the air, even with a vacuum pump. Used the clear tube method from passenger side to master cylinder, still no pedal holding.
Aug 9, 2019 at 1:58 AM
