Brake pedal goes to the floor
71,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BOBWENDRY1
Bake pedal goes to the floor, no fluid leaks.
Aug 24, 2018 at 4:01 AM
Good afternoon.
Any recent work done? Master cylinder is a common issue for no brake pedal. Check the fluid level.If you have ABS, there may be air in the system. I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Apr 14, 2021 at 6:35 AM
