Repair Safety Notice:
This information is for general instructional purposes only. Vehicle repair can be dangerous.
Verify all information, follow manufacturer service procedures, use proper tools and safety equipment,
and consult a qualified repair shop when needed.
CAR REPAIR CONTRIBUTOR
Good afternoon.
Any recent work done? Master cylinder is a common issue for no brake pedal. Check the fluid level.If you have ABS, there may be air in the system. I would suspect there is air in the lines. These guides can help you fix it.
