Brake pressure
167,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
MICHAEL MCCALL
I get brake pressure when the truck is off as soon as I turn it on it goes straight to the floor. I already changed the master cylinder.
Jul 26, 2016 at 12:46 PM
  • 55,694 POSTS
You need a scanner that can work the ABS valves open when the system is being bled. Can I ask if you had any kind of work done or did this just happen?
Mar 10, 2021 at 3:13 AM
CHRISTOPHER NULL
  • 11 POSTS
I blew a brake line on a test drive. I replaced the bad line and that is where I am at now.
CHRISTOPHER NULL
  • 11 POSTS
I also heard of the auto bleed sequence from the scan tool also.
If you have a scan tool, go to the ABS portion of the menu and then look for bleeding procedure. This procedure will not run if you have any active codes. Make sure the ABS light is not on. If it is, clear the code and then perform the procedure. You may have to do it several times to get all the air out of the unit.
CHRISTOPHER NULL
  • 11 POSTS
My best friend just dropped his off tonight. So tomorrow, as soon as I get home, I will be trying it out. I have heard if you can get the wheels to slide it will do the same thing. Is that hard on the unit? Neither my brake light or ABS light is on in the cluster.
CHRISTOPHER NULL
  • 11 POSTS
I have seen this issue on several different forum sites. Has anyone actually found a solution yet?
No, getting the wheels to lock does nothing. It will not bleed the system.
That is false information.
