Brake pressure
70,000 MILES • 1.9L • 4 CYL • TURBO • 2WD • MANUAL
C4RL
Hi, my brakes keep sucking in air after a few days of being bleed and travel to the floor. The garage has changed the master cylinder the servo and ABS module and it is still the same. I have had this issue for around nine months and two separate garages cannot seem to find the cause. There is no loss of fluid just air coming in, the garage have advised that all the air is in the front brakes. Any advise?
Dec 31, 2016 at 7:33 PM
  • 55,711 POSTS
Hey C4RL,
There is only one way air can be getting into the system and that is through the seals of the brake calipers or wheel cylinders. I have seen this problem before because the seal are meant to hold fluid in and when you let up on the pedal they can allow air in.
Best, Ken
Jan 1, 2017 at 2:07 AM
JOHNNY G.JR
  • 320 POSTS
2CarPros thanks for clearing that up.
Jan 1, 2017 at 2:13 AM
  • 55,711 POSTS
No problem Johnny G.
Best, Ken
Jan 3, 2017 at 4:50 AM
C4RL
Thanks for your help guys, I will advise on the outcome.
Jan 3, 2017 at 4:58 AM
