Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Brakes
Symptoms
Pedal Spongy
Brake pedal is low and soft
2003 FORD F-150
245,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
STEVE FINDLAY
MEMBER
1 POST
I had to replace the brake line on the right side. I have bled it but I cannot get the drivers side bled screw loose.
Sep 30, 2019 at 8:02 AM
Experienced Mechanic
Good evening.
You can try adding some heat from a torch to the area around the bleed screw and see if it comes loose.
If it does not, you will need to replace the caliper.
https://www.2carpros.com/articles/brake-caliper-replacement
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Mar 10, 2021 at 3:00 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
