brake pedal and release it it does not return fully
240,000 MILES • 6.6L • V8 • 2WD • AUTOMATIC
ARMAND671
  • 8 POSTS
When I push in the brake pedal and release it it does not return fully.
Oct 19, 2018 at 6:31 PM
Good morning.
If it does not return fully, either the brake pedal fulcrum which is what the brake pedal runs on under the dash is rusted and needs some lubricant or the power brake booster is the issue.
If you do not have power brakes, then it could also be the master cylinder itself sticking internally.
Jun 1, 2021 at 3:48 AM
ARMAND671
  • 8 POSTS
Thank you. I will try lubricating the fulcrum first and see if that resolves my issue. I do not have power brakes so it would probably be the master but I do know it was changed before I got the truck. Which was two months ago I was having to raise the pedal with the top of my foot that was an interesting drive.
You are welcome.
Let me know if you have more questions.
Always glad to help.
ARMAND671
  • 8 POSTS
Well, I lubricated the fulcrum and it is not returning fully when running but it does when it is off. Would if be the master or the booster? Or should I replace both?
You stated you had no power brakes but you asked about the booster? Please clarify.
If you have a booster, you have power brakes. If it does it running and not off, then it is the booster itself.
ARMAND671
  • 8 POSTS
Okay thank you. I thought it did not have power brakes, but I was mistaken. Sorry for the confusion. Thank you again for your input.
You are welcome.
ARMAND671
  • 8 POSTS
So I replaced the brake booster and it's still doing it. So how much vacuum should I be getting from the brake booster hose would that have anything to do with it? I took it off and ran the engine and I could put my finger in it and I feel a little vacuum. I am going to replace the master cylinder next and I checked all my brake lines and wheel cylinders they all check out good.
There should be 18-20 inches of vacuum.
Loosen the bolts for the master cylinder and see if the pedal returns.
New or rebuilt booster?
ARMAND671
  • 8 POSTS
New
ARMAND671
  • 8 POSTS
I will try loosening the bolts thank you again.
Okay, did you unbolt the master cylinder and see if it still happened?
ARMAND671
  • 8 POSTS
Not yet I will let you know the outcome as soon as I get to it probably after work tomorrow.
Sounds like a plan.
