brake pedal will not pump up
1991 MAZDA B2600
87,000 MILES • 2.6L • 4 CYL • RWD • AUTOMATIC
BILLMILL5050
  • 66 POSTS
my brake petal goes to the floor .it wont pump up when cranked or when key is off . I still have fluid in the resivor.what do I check .somebody said booster.i don't know the abs came on and went back off
Aug 25, 2016 at 11:19 PM
HMAC300
  • 48,601 POSTS
you probably either have a bad master cylinder or air in system or both. Have a pro check this
Aug 26, 2016 at 9:29 AM
BILLMILL5050
  • 66 POSTS
thanks, i didn't know overloading would make brakes go out.i put about 1100 lbs load on back and when i got home ,no brakes. but next morning i had brakes again.i didn't drive any different. i went ahead and flushed and bleed. thanks for the help
Aug 27, 2016 at 10:27 PM
RENEE L
  • 1,260 POSTS
Glad we could help please 2CarPros any time
Aug 31, 2016 at 4:55 PM
