Brake pedal travels to the floor?
230,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
MARIO TRIDENTE
Brake pedal travels to the floor after changing master cylinder, ABS module and both front calibers condition still exists still.
Sep 15, 2020 at 3:37 AM
  • 110,248 POSTS
When the pedal goes to the floor, the first thing I suspect is the master cylinder, but you have replaced it already. Did this happen prior to replacement? This guide can help us fix it
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
I will also need to know if this vehicle has a traditional vacuum assist power brake booster or does it have the hydroboost system. Additionally, how was the system bleed and what conditions still exist with the ABS module and the front brake calipers?
Mar 16, 2021 at 3:10 AM
