Replaced master cylinder, bled brake lines four times and pedal is still going to the floor. I am lost I think I need front pads.Thank you!
Jan 5, 2019 at 11:19 PM
✓Experienced Mechanic
You could be correct that pads need replaced at this point however, here is a guide that will help with this issue and another guide that will cover how to bleed the brakes in case you are missing something:
