Brake pedal to floor
27,000 MILES • 6 CYL • 2WD • AUTOMATIC
TCGOLF59
I was getting a whining noise from front so I changed the wheel bearings.please note the bearings I purchased are for ABS brake system and I don't have ABS brakes, however when I spoke with a local friend he stated that as long as the bolt pattern was the same there should be no problem with using them as I already had the others off the vehicle when before I noticed they were different. everything bolted up fine and I test drove the vehicle and all seemed well. until my wife drove the vehicle and noticed a bad vibration when braking and it would not got away. then it would, then it would come back.. I assumed the problem was a sticking caliper or failing brake line. so I purchased both and replaced both lines and calipers on the front of the vehicle. .after completion I went to bleed the brake lines and the brake pedal went to the floor especially when the vehicle was started. bled the brakes lines 2-3 more times and never could get pressure at the pedal.. I then purchased and put on a new master cylinder and bled the brake lines 2-3 more times. I still have no pressure the the brake pedal. Getting very frustrated.
Aug 17, 2020 at 2:34 AM
Good afternoon,
You need to pressure bleed the system for the pedal.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Did you bench bleed the master cylinder? If you did not, it will make the bleeding more difficult.
You need to get a pressure bleeder. You can rent one at a parts store. It is where pressurized air is forced into the master so when you open the bleeder, the air will be forced out.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
As far as the brake vibration, that is from a out of round rotor. Replace the pads and rotors and that will go away.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Aug 17, 2020 at 3:20 AM
TCGOLF59
Yes Roy, I bench bled the master before putting on. then bled again after the install at the lines coming out. I've not heard of a pressure bleeder but I will look into it. Thank you.. as far as the rotors being out of round.I will look at them as well. Much appreciate your input and assistance.
Aug 17, 2020 at 5:56 AM
You are welcome.
Always glad to help.
Aug 17, 2020 at 6:12 AM
