My van had its brake pads replaced and since then it has had a rubbing noise (almost a groan). It is getting worse and today the abs light came on. When you are going straight or turn to the right you can hear the rubbing noise but when you turn or veer left it goes away. The rotor was not replaced and I was wondering if that could be the problem. There was no rubbing noise before the brakes were changed! Please help!!
Sep 19, 2008 at 10:12 AM
