front wheel speed sensor replaced
82,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JESSICA TAYLOR-DOWNS
ABS Brake warning light is on telling me I need the front wheel speed sensor replaced.
Dec 13, 2019 at 11:49 PM
If the wheel speed sensor has failed we need to make sure it is the sensor itself so here are some guides that will help with this:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
If the sensor is the issue then here is a guide that will help with us:
https://www.2carpros.com/articles/how-to-replace-an-abs-wheel-speed-sensor
Below you will find the process from the manual on how to replace the speed sensor. Please let us know if you other questions. Thanks
Mar 11, 2021 at 10:06 AM
  • 55,647 POSTS
this guide can help:
Mar 15, 2021 at 12:24 PM
