Brake pedal soft and goes all the way to the floor
1998 TOYOTA COROLLA
19,000 MILES • 1.2L • 4 CYL • 2WD • AUTOMATIC
ROGER GARY LYONS
MEMBER
1 POST
Brake pedal going all the way to the floor. Master cylinder has been replaced. Bled system twice. No external leaks. Brakes have been replaced.
Apr 23, 2018 at 5:14 AM
CARADIODOC
✓Experienced Mechanic
Does the car have anti-lock brakes? If it does, you will likely need a scanner to command the computer to open two valves to allow those chambers to be bled in the hydraulic controller. Air gets into them if you allow the reservoir to run empty or if you bleed at the wheels after replacing the master cylinder, or if you did not bench-bleed the new master cylinder. Once we have this solved, I can share a simple trick so you do not have to bleed at the wheels.
Apr 23, 2018 at 11:32 AM
