Brake pedal sinks to the floor?
98,000 MILES • 1.2L • 2WD • MANUAL
H1XXI
Brake pedal slowly sinks to floor and works better if pumped. Installed a new master cylinder, new rear brake wheel cylinders two times, front brake pads and a brake fluid change.
Mar 26, 2023 at 12:54 AM
  • 110,244 POSTS
It sounds like you still have air in the system. On these vehicles, I have found that you need to use a brake bleeder at the master cylinder to pressure bleed the system.
I attached the directions below. Try this and let me know if it takes care of the issue.
Mar 26, 2023 at 2:19 PM
