Brake pedal goes to the floor
40,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
GARCIA69
When pushing on the brake pedal it goes all the way down and the car slowly comes to a stop. I changed master cylinder and bleed the brakes and no change.
Aug 18, 2018 at 5:13 AM
  • 110,248 POSTS
Does this vehicle have four wheel drum brakes? The most common problem is the brake shoes being out of adjustment. Also, when you bled the brakes, did you start at the wheel furthest from the master cylinder and work your way to the closest?
Here is a link that shows replacing drum brakes. It includes adjustment.
Take a look through this and let me know if it helps.
https://www.2carpros.com/articles/how-to-replace-rear-brake-shoes-and-drums
Aug 19, 2018 at 12:01 PM
GARCIA69
Thanks for the response. No the car has rear drums and has disk in front. I will be adding a new booster tomorrow to add to the new master cylinder. Also the tears were adjusted by mechanic reacently. Still car does stop but I need to slam pedal to floor.
Aug 19, 2018 at 12:14 PM
  • 110,248 POSTS
I have to be honest, I do not think a new booster is going to help with this problem. This sounds like either there is still air in the system or the rears are totally out of adjustment. If you lift the vehicle and turn the wheels by hand and then have someone step on the brake, do the wheels stop right away? Also, if you pump the brakes, do you get a better pedal?
Aug 20, 2018 at 11:31 AM
