pedal is still sinking to the floor
308,051 MILES • 5.3L • V8 • TURBO
KELVIN MORRIS
I replaced the brake calipers and master cylinder and the pedal is still sinking to the floor. what is the problem?
Sep 13, 2016 at 7:48 AM
HMAC300
  • 48,601 POSTS
I would suspect there is air in the lines. These guides can help you fix it.
https://youtu.be/w7gUsj2us0U
and
https://youtu.be/WDxvEQrMkBg
and
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Mar 11, 2021 at 5:21 AM
DDUNCAN70
Did you ever get this figured out .i have the same problem no leaks new master cylinder new calipers .Had a mechanic pull it in to his garage to check for leaks and bleed the system still no pedal.they worked fine until a brake line blew out and I replaced some line two calipers and master cylinder .everything was bled and checked for leaks
  • 55,511 POSTS
You need to have a scanner connected the ABS system so you can open the ABS valves which will get the air out.
This video will show you how to connect the the ABS system.
https://youtu.be/rTtAnsOlZU4
This guide can help as well
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Please let us know what you find.
Cheers, Ken
DDUNCAN70
I bought a scanner and did an abs auto bleed .still no luck you can feel the abs push against you when the pedal goes to the floor .you can hear humming when you hold the brakes to the floor.I have someone looking at it soon .I agree maybe it’s in the abs
  • 55,511 POSTS
Sure sounds like it but to be sure lets use four vise grips and gently close off the rubber flex hoses. Once complete check the brake pedal it should be hard if there is a wheel issue and soft if it is the master or ABS.
Please report back
Cheers, Ken
DDUNCAN70
I took my Yukon to a second mechanic.Found out the calipers were on opposite sides .The bleeder valves have to be on top .I had replaced the rear calipers and those were fine but the front ones were mixed up .Not sure how they bled them before but if the bleeders are not on the top they are on wrong they won’t bleed correctly..thanks for the replies.brakes are great now
  • 55,511 POSTS
Yep the calipers need to be on the correct side that's for sure quick pictures of the brakes and I could have lead us to the conclusion. Glad you got it fixed.
Use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
