Brake pedal going to the floor.
2000 OLDSMOBILE SILHOUETTE
230,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
KLAUTO
I have a 2000 Oldsmobile Silhouette. Brake pads have been replaced on front and back, new master cylinder, new brake booster, and brakes have been bled all the way around 4 different times, the pedal still goes to the floor. I am at a loss of where else to check. Do you have any suggestions?
Feb 4, 2016 at 5:14 AM
CATAFINA
  • 167 POSTS
If its not leaking anywhere go back and double check the master cylinder
Feb 4, 2016 at 6:54 AM
HMAC300
  • 48,601 POSTS
you probably have air in abs unit and has to be bled properly. try using a power bleeder as it can take up to 3 qts. to do it.
Feb 4, 2016 at 8:09 AM
