Brake pedal goes to the floor with the engine off
1999 GMC C3500
107,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DWANE MENKE
Brakes were working fine until I hit a patch of ice. The ABS system engaged worked properly, but right after the ABS went on I lost pressure at the pedal. I have inspected each wheel I did not see any brake fluid leaking. The master cylinder was low but not empty. I am thinking it may be the master cylinder or the brake booster. Any help would be appreciated.
Jan 3, 2017 at 11:09 PM
HMAC300
  • 48,601 POSTS
It sounds like the master when bad which is common when the ABS came on here is guide to help you replace the master.
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
Jan 4, 2017 at 4:21 AM
JAMIEJONES
I had this problem and had to replace the master cost me $132.00 all fixed great guide BTW.
Jun 25, 2019 at 10:10 AM
