Brake pedal goes to the floor when car is on
190,000 MILES • 2WD • MANUAL
JBOTSCH
The other day my brakes went out as I was going downhill then when I backed up they worked again. I was told it might be the brake cylinder. My friend put in a new brake cylinder from O'Reilly's and now it is doing the same thing again. What could be wrong? I get pull push and pull when the car is off but when it is on I get nothing but to the floor.
Sep 7, 2018 at 10:41 AM
  • 110,248 POSTS
Are you certain there are no leaks? When you say brake cylinder, are you referring to the Master Cylinder or a wheel brake cylinder? Was the system properly bled?
Take a look through this link and see if there is anything that you find helpful.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Let me know if that helps or not. If you have other questions or need more information, let me know.
Sep 7, 2018 at 12:44 PM
