Brake pedal goes to the floor when engine Is running.
Jun 24, 2020 at 2:02 AM
✓Experienced Mechanic
Good morning,
Sounds like you either have air in the system or a failed master cylinder. I would suspect there is air in the lines. These guides can help you fix it.
