brake pedal goes to floor when car is running?
100,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
THETANK
  • 5 POSTS
replaced all 4 calipers, master cylinder and power booster. bleed brakes. with car off good pedal. start the car and pedal goes to floor.
Apr 27, 2023 at 8:35 AM
  • 110,248 POSTS
Did you bleed the ABS? The ABS portion of the brake system must be bled separately using a bidirectional scanner.
Take a look below. I attached the directions. Let me know if this is something you can do or have done.
You likely have air in the system.
See pic below.
Apr 28, 2023 at 4:39 PM
THETANK
  • 5 POSTS
bled the ABS system four times. pedal is a little better but still goes too low.
Apr 29, 2023 at 2:42 AM
  • 110,248 POSTS
Did you follow the sequence listed in the directions? It indicates a standard bleed, then the ABS, then a standard bleed again.
What you are describing is either air in the system or a bad master cylinder. I've seen situations where the push rod between the booster and MC wasn't properly seated causing similar issues. Everything went back together easily, correct? Also, before installing the new master cylinder, was it bench bled?
Apr 29, 2023 at 12:21 PM
THETANK
  • 5 POSTS
Yes, bench bleed master cylinder and went together easy and adjusted the free play on the booster. when the car is not running there are awesome brakes. Plugged the vacuum line at the intake and running without booster it stops good. Hook vacuum back to booster and they go to floor.
Apr 30, 2023 at 7:42 AM
  • 110,248 POSTS
If the booster was causing the issue, the brakes would lock up if they went to the floor. That isn't the case. Are you able to pump up the brake pedal if the booster is connected? I ask because all the booster does is provide assistance (which makes it easier to press).
Apr 30, 2023 at 11:30 AM
THETANK
  • 5 POSTS
it does not pump up.
May 1, 2023 at 8:00 AM
  • 110,248 POSTS
When you bled the ABS, was it done via the data link connector with a bidirectional scan tool? That's the only other thing that makes sense.
May 1, 2023 at 1:29 PM
THETANK
  • 5 POSTS
yes, also tried new master cylinder with no changes.
May 6, 2023 at 2:02 AM
  • 55,673 POSTS
It isolates the problem gently take four vise grips and close off the flex hoses that go to the wheels to see if the pedal stays hard, if so the problem is a the wheels if not the problem will be with the master. Did you bench bleed the master, if not this can be the problem here is a guide and a video to help us with the problem. Also, when you say you bled the ABS did you open the ABS valves?
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
and
https://youtu.be/nQRnKyVyMuQ
and
https://youtu.be/WDxvEQrMkBg
Please go over these guides and report back.
May 7, 2023 at 2:58 AM
