Brake pedal goes to floor but works if pumped
160,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ANGELA RICHARDS- JOHNSON
Hi, our van has been to multiple mechanics. we had good brakes but our ABS was not working. our mechanic put in a new ABS module now the ABS is working, but the brakes are horrible unless I pump them. we have changed the calipers, master brake cylinder twice because we thought the first one might be faulty. all rotors and pads have been replaced, bled out the system by three different mechanics and the brake lines have all been tested for leaks by a certified mechanic and no leaks. We do not know what to do now, any suggestions?
Thanks,
Angela
Feb 8, 2017 at 1:08 PM
AL514
  • 5,676 POSTS
The ABS module has to be bleed using a scan tool that can command the solenoids open. There is still air in the system, pumping up the pedal is just building pressure temporarily. Common issue when the ABS mod. is replaced. They need to be bled correctly.
Feb 21, 2021 at 3:08 AM
The dealership said that they did that, they bled the ABS system and said they activated the ABS module and that it must be the master brake cylinder causing the problem. After replacing it again we had the same result.
AL514
  • 5,676 POSTS
Then they diagnosed the problem wrong. After replacing the master you will have to re-bleed the ABS system again or you will still have air in the lines. They should have been able to repair this problem for you from the start. They are the most qualified techs for this vehicle. There should be no reason they are not directing you in the right direction. They are supposed to be the expert's.
