When turning the steering wheel completely to the left the brake pedal goes down to the floor
90,000 MILES • 2.7L • V6 • 4WD • AUTOMATIC
ELDOCYRUS
Hi there,
This only happens when making a hard left turn. Other than that it brakes perfect.
Paid a lot in repairs already, they bled the whole system and also changed the master. Now they want to scan it but don’t have too advanced scanners I think.
Is this maybe a axle bearing failure?
Would it be the left side since it only happens when turning left?
Hope you can help me out.
Apr 5, 2019 at 11:35 AM
JOETECHPRO
  • 705 POSTS
Hey ELDOCYRUS,
Checking for play in the wheel bearings is a great idea.
It is easy and quick to do, a badly failed bearing will give enough play that the brake rotor can shift.
This will need to be ruled out before you go any further, i'm surprised they have not checked this already.
Let us know after you have had the front wheel bearings checked.
Regards, Joe
Apr 7, 2019 at 4:30 AM
