Brake pedal goes straight to the floor
180,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
4MARTYA
Changed the master cylinder and changed a brakeline. Now I have no brakes at all. I hear a leak from the new line at the fitting I think. And I can't get the driver front bleeder valve to open to bleed. Would that cause me to have no brakes at all?
Jul 4, 2019 at 6:17 AM
  • 110,248 POSTS
Welcome to 2CarPros.
If you aren't able to bleed that, most likely the system has a lot of air in it and is causing the problem and if there is a leak, it needs fixed.
Confirm there is no leak or it is repaired. Then we have two choices, replace the caliper with the stuck bleeder, or work at getting it opened.
When I have one that won't open, I first take a wire brush all around it to remove any corrosion, dirt, rust... Then spray it with a good penetrating oil and let it work at it. See if that helps.
Mar 10, 2021 at 3:00 AM
