Brake Pedal Goes Nearly to Floor?
123,000 MILES • 1.9L • AUTOMATIC
DAVIDKRISS
  • 19 POSTS
I was responding to another thread and for some reason it was cut short and the mechanic's last entry was removed, but he had sent me two links to review, this being the primary one.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor/
So to pick back up, thank you -- I've reviewed the links and here are my thoughts:
The car (1999 Saturn SL2) has:
No ABS, New master cylinder (which remains full - no leaks), new front brake calipers, rotors, and pads, new back drums and shoes, new brake fluid bled through this weekend, good brake lines with no cracks.
All brake pads and shoes have even wear from the little I've driven and actuate properly when on a lift with the tires off.
I'm at a loss other than a possible bad drum cylinder, but I don't see any leaking brake fluid anywhere. Looking forward to your thoughts.
Jul 21, 2026 at 9:42 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the completed work and pedal operation verified before relying on the reported improvement. If excessive travel returns, stop driving and have the hydraulic system, component installation and rear-brake adjustment inspected using the correct service procedure. Do not use driving as a method of correcting a low pedal. The thread does not isolate a failed component, and the final suggestion of a sticking caliper slide was not confirmed.
Guidance references and applicability
Source discussion: question 1713057 https://2carpros.com/questions/brake-pedal-goes-nearly-to-floor--1713057 Supports the reported history and outcome only. Follow-up guidance is editorial synthesis; unverified specifications and diagnoses are not adopted. HELLA: Checking the brakes https://www.hella.com/techworld/uk/technical/brakes/checking-the-brakes/ General brake-inspection background. Not a vehicle-specific booster, ABS, bleeding or adjustment procedure; it does not establish the cause in this discussion.
Read the replies · Discussion summary and reported outcome
  • 55,691 POSTS
If the rear wheel cylinder does not have any leaks they are probably okay. Can you set the parking brake to see if it helps the pedal? Also, you will have a low pedal if the calipers or pads are not correctly mounted. If the parking brake helps I would recheck the rear shoe adjustment. Here is the guide link again for clearity.
You still may have air in the system as well. Also, can I ask if the brake bleeder on the calipers is at the top of the caliper, sometimes they get installed on the wrong side. Plus make sure the brake flex line is not twisted. Let me know.
Jul 21, 2026 at 10:25 AM
DAVIDKRISS
  • 19 POSTS
Thanks --
I set the parking brake and it didn't help with the pedal.
The brake bleeders are at the top of the calipers and the brake flex line looks good - no twisting.
I bled the brakes this past weekend by pumping the pedal and when the car is off, the brake pedal builds up good resistance. When I start the car, that's when it drops down 3/4 of the way to the floor before engaging.
I have a pressurized brake fluid bleeder - I'll use it to bleed the brakes completely on Friday and see if that makes a difference. I'll also double check the shoe adjustment on the drums to make sure they're set properly.
I'm at a loss as to the cause because it seems like I've ruled out the most common causes. What else could it be?
Jul 21, 2026 at 2:47 PM
  • 55,691 POSTS
Do me a favor and open the bleeder one at a time to see if any air comes out of a particular caliper or wheel cylinder. You don't need to press on the pedal. Let me know
Jul 22, 2026 at 7:55 AM
DAVIDKRISS
  • 19 POSTS
Sorry for the delay - it took some time to get the car back on the lift. There didn't seem to be any air coming out of any of the bleeders. We replaced the rear drum cylinders, adjusted the shoes and the emergency brake, then used a pressurized system to bleed the brakes... the pedal kept going to the floor when I started the car.
I listened for vacuum leaks going to the brake booster and didn't hear anything, so we bleed the brakes several more times using the pump method and then test drove the car... I'm not sure what changed, but the brake pedal is holding appropriate pressure now. It seemed to go to the floor after the last bleeding but after driving it, that's when the pedal somehow took on a firm resistance which remains consistent now.
I'm stumped but things seem to be working much better now. Thanks for everything. Cheers.
Aug 17, 2026 at 11:52 AM
  • 55,691 POSTS
Does this car have ABS brakes? I am glad things worked out for you.
Aug 18, 2026 at 6:22 AM
DAVIDKRISS
  • 19 POSTS
Thank you! The car does NOT have ABS brakes.
Aug 21, 2026 at 11:30 AM
  • 55,691 POSTS
Hmm,, it might have been a stuck caliper slide.
Aug 21, 2026 at 6:02 PM
Discussion summary
The owner of a 1999 Saturn SL2 without ABS reported excessive brake-pedal travel after extensive brake work. Rear wheel cylinders were subsequently replaced, the shoes and parking brake adjusted, and the system bled repeatedly. The owner eventually reported a consistently firmer pedal but could not identify which action resolved the condition.
Reported outcome: The owner reported improved, consistent pedal resistance after multiple repairs and bleeding attempts.
Several actions occurred together. The record does not establish a single cause or a professionally verified final brake-performance test.
Read the original discussion
