brake pedal goes almost to floor but brakes do stop truck
117,300 MILES • 3.5L • 5 CYL • 4WD • AUTOMATIC
GOOD4611
I replaced the rear wheel cylinders because the bleeders were broke, replaced the master cylinder because mechanic said it was the issue also replaced the ABS unit. Bled the system from back to front. The front calipers and pads were replaced just prior and truck sat unused for one year just before parts were replaced. The brake pedal now goes to floor, I can pump the brakes up with the car off and as soon as I start it the pedal goes to floor. I have tried to bleed the brakes again but pedal goes to floor. I did bench bleed the master and checked to make sure it holds by plugging the lines and pushing on rod with screwdriver. Not sure if the ABS unit is holding air causing my issue. Help!
May 21, 2018 at 12:53 PM
AL514
  • 5,690 POSTS
Yes unfortunately it sounds like the ABS unit is not bleb properly, and most times you will need a scan tool to open up the solenoids in the module to get all the air out, this will regain pedal height and remove the excess air.
May 22, 2018 at 12:34 AM
