Brake pedal goes almost to floor
2002 ACURA RSX
200,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SAMTWEEDY
Had bad brake line. So i replaced it the bled brakes. could not regain normal pedal. It will pump up but if you release it then press again it goes almost to floor. I then replaced master cylinder bench bleeding before installation. I then bleed brake system at ABS block then at each wheel in manufacturer's sequence. Pedal still goes almost to floor. I tried adjusting the push rod on the pedal and no luck there. I checked for leaks at all connections but found none.
Feb 16, 2019 at 6:22 AM
  • 55,432 POSTS
It sounds like you have air stuck in the ABS unit. you will need a scanner that can open the valves while bleeding the system. this is a common problem. here is a guide to help you:
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
and
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Feb 18, 2019 at 3:47 AM
