Brake pedal depresed and hissing sound
200,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JOSHUAFENDER755
  • 34 POSTS
I recently changed my brakes on my voyager and after about a month I noticed that I was loosing brake power and there is a hissing sound when I press down on my brakes. The brake fluid level is normal and the pads were installed correctly. Please help me to locate and fix the problem. Thank you
Aug 4, 2014 at 3:57 AM
  • 110,248 POSTS
When you experience the problem, is the brake pedal harder to push?
Aug 4, 2014 at 12:41 PM
JOSHUAFENDER755
  • 34 POSTS
No the brake pedal is not harder
Aug 4, 2014 at 1:08 PM
  • 110,248 POSTS
I believe the power brake booster is bad. It is vacuum operated and mounted behind the master cylinder. Open the hood, start the car, and have a helper depress the brake. See if that is where the hissing is coming from. Also, check the vacuum hose between the booster and the engine intake.
Aug 5, 2014 at 11:33 AM
