Brake pedal almost to the floor
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
RHOWERT13
Replaced master cylinder, brake booster, front calipers, new brake lines. Bled lines, and the whole system and the pedal still goes almost to the floor.
Nov 12, 2017 at 5:51 AM
WRENCHTECH
  • 20,758 POSTS
You do not state what you were trying to fix in the first place before changing all those parts, but on that vehicle once air is in the system it has to be electronically bled using a bidirectional scan tool.
Nov 12, 2017 at 10:10 AM
RHOWERT13
Thank you for your response. I will have to see if I can buy one of those bidirectional scan tools. It is been this way for years.
Nov 12, 2017 at 8:52 PM
WRENCHTECH
  • 20,758 POSTS
Since the cost of the tool is in the vicinity of $10,000, I would suggest you just have it done by a professional shop.
Nov 12, 2017 at 9:05 PM
RHOWERT13
Wow, okay. thanks.
Nov 12, 2017 at 9:28 PM
