brake pedal pulsating makes a grinding
101 MILES • 3.5L • V6 • 2WD • AUTOMATIC
KAET71761
When you press the brake pedal it puts up a resistance like pulsating makes a noise like something is grinding. When you force the pedal down it feels like it's not going to go down then it will feel like it won't stop you but it always does. We just changed fluid and bled them thinking air in lines but it changed nothing.
May 17, 2020 at 6:40 PM
Good morning,
Is the ABS yellow light on at the dash?
https://www.2carpros.com/articles/how-to-replace-a-abs-controller
This sounds like the ABS is activating every time you apply the brakes. The grinding is the unit itself and the pulsation is the ABS as well.
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Can you get the codes checked at a parts store to see if there is any codes set? That will tell me the area of failure so I can guide you.
May 17, 2020 at 10:15 PM
KAET71761
Hi Roy,
Thank you so much for your response. No the ABS light doesn't come on. If you can tell me how to retrieve the codes I will make every effort to do so.
May 18, 2020 at 12:01 AM
KAET71761
Oh I am sorry, I have a friend who is willing to help me retrieve those codes. He asked about turning the ignition key 3 times? Would this be a way to get to the codes?
May 18, 2020 at 12:03 AM
You will need a scan tool that can access the ABS system. If you do not have one, a parts store should be able to read them for you for free.
May 18, 2020 at 12:04 AM
No, not at all. You need a real scan tool that can read the ABS system and retrieve the codes.
May 18, 2020 at 12:08 AM
KAET71761
Thank you so much. I will run it to the parts store and get back to you when I know more.
May 18, 2020 at 3:20 AM
You are welcome.
Keep me updated.
May 18, 2020 at 3:23 AM
