Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Highlander
Brakes
Caliper
Replace/Remove
caliper bolt torque specs?
2012 TOYOTA HIGHLANDER
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
TJMOWBRAY
MEMBER
Changing the brake pads on the vehicle listed above and needing brake caliper bolt torque specs.
Jun 27, 2025 at 1:44 PM
Experienced Mechanic
The front caliper torque specs are
Torque : 34 Nm (347 kgf-cm, 25 ft-lbf)
The rear caliper torque specs are
as well. Let us know if you need anything else.
Jun 28, 2025 at 5:38 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
