How to change the brake fluid?
121,000 MILES • 2.0L • 4 CYL • TURBO • AUTOMATIC
MHADADI
How can i change brake fluid? how i know it needs change or not?
Aug 27, 2021 at 5:16 PM
SQM
  • 6,383 POSTS
Changing the brake fluid is a recommended maintenance for your vehicle.
Lexus recommends changing the brake fluid out every 30,000 miles.
Just like any other fluid as they get used there are break down in the molecule level of the fluid also it can trap debris overtime as well. Having old fluid can impact the way your vehicle brakes.
So it is a good idea to change the brake fluid at regular interval.
You will find these videos helpful:
https://youtu.be/w7gUsj2us0U
https://youtu.be/nQRnKyVyMuQ
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Aug 28, 2021 at 3:08 PM
