Brake noise and vibration in pedal when slightly depressed?
110,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
MARYLEE FERRY
Brakes work fine but when just light pressure on pedal a clicking vibration and noise felt in pedal only.
Mar 8, 2023 at 4:37 AM
  • 110,248 POSTS
If you feel it in the pedal, chances are it is related to a warped brake rotor. Since you only notice it at the pedal, there is a good chance it is the rear brake pads/rotors.
Interestingly, I found a technical service bulletin (TSB) related to brake pad issues. I attached it below for your review.
By chance, have the brakes been worked on recently? I realize the vehicle has 110K on it so the pads are not original, but the TSB could be relevant if the old design was used.
Mar 8, 2023 at 11:35 AM
