Squeaky noise when pressing the brake pedal
195 MILES • 2.0L • 4 CYL • AUTOMATIC
SANDYDEE
I just had brakes pads and rotors done two months ago. Everything was fine. But now as soon as I hit the brake pedal, there's a real squeaky noise. It only happens when I hit the brake pedal.
Oct 6, 2020 at 10:23 PM
Good morning,
If the pads are new, then good chance it is either the material of the pads itself causing the noise or it could be the rotor. Check and see if the rotors have heat marks on them such as blue or black spots.
If you used metallic pads, the noise is not uncommon.
The other thing is the clips that hold the pads from moving inside the caliper mounts. If the pads move, it will cause a noise.
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
What brand did you use?
Mar 31, 2021 at 5:36 AM
