brake noise
162,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JOE1953
  • 814 POSTS
when I step on the brake when coming to a stop just before I make a complete stop I can hear a sqeaking noise what could be causing the sqeaking noise? the brake pad don't have to much wear on them.
Apr 1, 2016 at 2:16 PM
JOHNNYT73
  • 924 POSTS
How old are the pads? There is usually a warning tab on the pad that will begin touching the rotor when the pads get close to needing replaced.
Apr 1, 2016 at 11:50 PM
JOE1953
  • 814 POSTS
I replace the front pads December 7, 2014, I didn't see no warning tab on the pads.
Apr 3, 2016 at 10:18 AM
JOE1953
  • 814 POSTS
I replace the front pads December 7, 2014, I didn' t see no warning tab on the pads.
Apr 4, 2016 at 2:56 PM
SATURNTECH9
  • 30,868 POSTS
Just to add to this one what kind brand etc pads were they?We're they the cheapest pads you could find?The cheaper the pad the quicker the pads wear out and the noisier they will be .So did you see if the pads were worn out?
Apr 6, 2016 at 5:34 AM
JOE1953
  • 814 POSTS
yes I got the cheapest pads, no the pads is not worn out.
Apr 7, 2016 at 1:33 AM
SATURNTECH9
  • 30,868 POSTS
Alright the cheapest pads wear faster usually they crack also plus they make a lot more noise while stopping.That's why I use the premium pads on my car and when ever I do brake jobs for people.I personally use centric possi quite brake pads.I use to use the on the police cars and police suvs they worked great.
Apr 7, 2016 at 5:10 AM
JOE1953
  • 814 POSTS
the noise I hear when I step on the brake could it be coming from a wheel bearing? I do have a bad bearing on the right rear but it make the noise just before I come to a complete stop,
Apr 11, 2016 at 1:25 AM
SATURNTECH9
  • 30,868 POSTS
The bad bearing make noise while your driving and not hitting the brake.if you a bad wheel bearing you should replace it.Also is the noise coming from the front or the rear?
Apr 11, 2016 at 5:13 AM
JOE1953
  • 814 POSTS
sound like the noise is coming from the right rear where the bad wheel bearing is i havn't check the brake shoes.
Apr 11, 2016 at 5:38 AM
SATURNTECH9
  • 30,868 POSTS
First thing you need to do is check the brakes where the noise is coming from.
Apr 11, 2016 at 5:40 AM
SATURNTECH9
  • 30,868 POSTS
The first thing you need to do is check those rear shoes .Also does the bad bearing have any play in it?
Apr 11, 2016 at 5:48 AM
SATURNTECH9
  • 30,868 POSTS
You could get some Emery cloth sand paper and lightly sand the rear shoes shoes to take the glaze off them.Then San the inside of the drum and clean everything up with brake cleaner.
Apr 11, 2016 at 11:59 PM
JOE1953
  • 814 POSTS
I don't feel any play in the bearing but when I turn the wheel I can hear a thumbing noise, the shoes are worn bad but they are not worn to the metal.
Apr 16, 2016 at 7:10 AM
SATURNTECH9
  • 30,868 POSTS
If you only hear the noise in the rear while braking then the noise is in the shoes /drum somewhere.You can't hear that bad wheel bearing while driving?
Apr 16, 2016 at 5:29 PM
JOE1953
  • 814 POSTS
I sand the shoes and drum I don't hear the noise when braking thank for your help.
Apr 17, 2016 at 1:33 AM
SATURNTECH9
  • 30,868 POSTS
Your welcome glad I could help you out
Apr 17, 2016 at 1:44 AM
