Brake mounting and realising
2007 NISSAN HARDBODY
50,000 MILES • 2.7L • 4 CYL • 2WD
C CHIGOGO
Brake pressure mounting after pumping the brake and when kept pressed for ten to twenty seconds releasing. I have changed brake pads, shoes, serviced the master cylinder and the booster, but still the problem persist. I have now changed mechanics three times.
Jul 7, 2018 at 11:47 AM
  • 110,244 POSTS
I am not sure I understand what you mean by mounting. Do you mean the brake will not release? Or, is the brake pedal going down when you hold pressure?
Let me know so I can better help.
Jul 8, 2018 at 2:42 PM
