Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-600
Engine
Camshaft
Pushrod
Cannot remove push rod out of master cylinder
1973 FORD F-600
100,000 MILES • 5.3L • V8 • 2WD • MANUAL
CHARLES STEELE
MEMBER
can't get the push rod out of the old cylinder and did not get a new one with the new master cylinder.
May 12, 2020 at 5:19 AM
Experienced Mechanic
Good afternoon,
The push rod is held in by a snap ring.
What you need to do is remove the boot from the back, then release the snap ring holding in the piston. Remove the piston with the rod.
You will have to cut the piston at the rod connection to release it and install on the new one.
May 12, 2020 at 6:26 AM
Add image or video
Ask a new question
Engine — Backfire
