Brake line replacement
185,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
DALLAS TAPLEY
I need a full brake system diagram to replace all brake lines.
May 18, 2018 at 7:43 AM
CARADIODOC
  • 34,415 POSTS
There really is no such diagram, even, as I recall, in the original paper service manuals. I will double-check that when I get home tonight, but the best way to approach this is to replace just one line at a time. If there are diagrams in the service manual, you are going to have to specify if the truck has rear-wheel-ABS, four-wheel-ABS, or just the standard base brake system.
May 18, 2018 at 8:52 AM
