Brake line
1996 TOYOTA TACOMA
180,000 MILES • 3.4L • V6 • 2WD • AUTOMATIC
TACOTUESDAY
Prior to removing the brake line to access the caliper bolts, do I need to clamp the brake line?
Aug 4, 2018 at 7:24 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
May I ask why you are removing the brake line? If you are just doing a brake job/pad replacement there would not be a reason to remove the line. Once the line is removed air will enter the system and you will then have to bleed all the air out of the system. I can give you tutorial links and diagrams if needed. Hope this helps and please ask any other questions if needed. Thanks for using 2CarPros.
Danny-
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Aug 5, 2018 at 4:50 AM
