Brake line
160,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ANDREW GRABER
  • 5 POSTS
Ok can you tell me what the part number is that connects to AcDelco part number 10408593 it's the rear section that goes to the flex line and then out to the wheel cylinder? So I can look it up and try to find it somewhere else since you said it's not available at GM
Nov 4, 2019 at 2:52 PM
Good morning,
Has anyone told you that line can be made from flex line and proper fittings? I never bought the lines from the dealer. I just got the line from a parts store and made the line to match the old line. It is much cheaper and easier to install.
Mar 12, 2021 at 3:15 AM
STEVE W.
  • 15,410 POSTS
The line in question is listed as the end fittings and the raw line, to be made as required as Roy mentioned. There may have been a part number when the car was made but GM doesn't list one now. Sorry.
