Brake lights wil not go out
235,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
EWINFREY
  • 6 POSTS
brake lights stay on, I replaced, lights, fuses, relays for dimmer, lights, I cannot locate stop lamp failure sensor, replaced brake light switch also. All 3 stay on L/R/Center. Check for grounds, loose wires, etc... nothing.
Feb 11, 2014 at 3:38 AM
CARADIODOC
  • 34,396 POSTS
Push on the brake light switch by hand. If the lights go out, look for a rubber cap that fell off the switch.
Feb 11, 2014 at 6:30 AM
EWINFREY
  • 6 POSTS
Replaced brake switch and made sure it was working correctly. No hole to worry about switch goes in and out but no effect on lights
Feb 11, 2014 at 7:26 AM
CARADIODOC
  • 34,396 POSTS
Unplug the switch, then see if the lights go off.
Feb 11, 2014 at 9:22 AM
HONDATECH1983
  • 109 POSTS
brake pedal position switch plastic stopper has most likely fell out.
Mar 2, 2014 at 9:46 PM
