Brake lights not working
210,000 MILES • AUTOMATIC
CELLOMASTA
All 3 brake lights are not working. I've tested the fuse, the brake light switch, and power is getting to the brake light switch. Looking for a wiring diagram I can use to trace the power/ground to the lights at the back of the car to see if the lightbulbs are getting power
Oct 16, 2026 at 11:20 AM
CARADIODOC
  • 34,413 POSTS
This is a pretty straightforward circuit. It can be hard to read, so I expanded part of it for you.
The third drawing is the best I could find to show the location of the under-dash fuse and relay box. Let me know if you need to remove it. There's about six pages of instructions on how to do that.
Oct 16, 2026 at 5:17 PM
